Old 07-18-2013, 01:54 AM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Originally Posted by LMH View Post
They were made of cast iron early on and cast aluminum later. Larry
The remains of early ones I have seen and or held were fabricated mild steel. (Upper bleeder tubes were also thin wall mild steel fabrications. SA did design drawings for the upper bleeder tubes. ) Few seemed to have survived. Owners in warm climates often did not use anti-freeze or other corrosion inhibitors it seems as badly corroded parts in the whole of the engine/cooling system were/are common. The steel one I borrowed for pictures and a reverse engineering study was severely corroded and the car owner had to have a new one fabricated.
The AC Cars supplied cast aluminum part used on most new street cars was mounted on chassis at their factory before shipping to America. I have held cast aluminum examples recreated by two companies and have seen pictures of ones made by others and heard of even more makers . Copies are not very rare. The new made copies I have held were heavier castings (thicker walls) than originals.
Dan Case
