Old 07-19-2013, 08:23 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by Shootnride View Post
The engine is a 427 SO with a 428 crank. Documentation that I have for the engine indicates that it was internally balanced but the harmonic balancer has definitely been balanced. Since the engine builder has passed away, I can't ask him any questions about the build, so thought it would be wise to use the existing balancer.
Ted
if your sure it was internally balanced, and if you have any receipts showing a big hunk of mallory metal
then that means the balancer is zero balance. and so will be the flywheel or flexplate
what your seeing in the work on the balancer is what he had to do to make it zero balance.
so you can buy an aftermarket balancer that is zero balance and use that instead of sleaving the old one
you could get the balancer checked to see exactly what it is.....
Fred B
