Old 07-20-2013, 02:29 PM
blykins blykins is offline
Little further today....
Got main bearing clearances checked. Well, I'll rephrase that...I checked the rear main just to see where I'd be. It was tighter than where I wanna be with a hotter (higher performance) aluminum blocked FE, at .0017". Typically, I'm at .0018"-.0020" cold on the main bearing clearances. I want to be closer to .003" on a hot bearing clearance with this one, so I had to order a set of "X" bearings, so I could half/half them.
Rod bearing clearances came in where I wanted.
Piston to cylinder clearance was good, and deck clearance is right where I spec'd it to be.
Cam thrust plate that I have here would need about .010" to be taken OFF just in order to get cam thrust clearance, so I ordered another one of those as well.
After the cam is degreed, then it will be balance time.
This week will be a little crowded. I dyno'd another big inch Windsor yesterday, and I need to get the bell dialed and the clutch assembled so I can ship it out. Then I need to start assembly on David Wade's 501FE, which will also get its own magazine article, so I have to take a lot of "quality" pictures.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
