Old 07-20-2013, 08:52 PM
lippy lippy is offline
Front suspension and brakes done, both sides.
I installed the pins on my bolt-on/5-pin adapters, and used the metal alignment guide to make sure they are straight. But when I tried to slide a wheel on, I couldn't get it to slide in. How difficult should it be to slide the wheel onto the pins? Do you lube the pins? Thanks.
Untitled by Lippy111, on Flickr
