Old 07-21-2013, 08:32 PM
racco's Avatar
racco racco is offline
Originally Posted by Eljaro View Post
the Contemporary assembly manual says
caster 3 to 5 degree positive
camber 0 to 1/2 degree negative camber
toe in 1/8"
rear camber 0 degrees.
I have the front set like Contemporary says and the rear with 1/2 to 1 degree negative camber.
Car behaves very well with these settings.
The lower you drop the rear end the more neg camber. I have 1.5 deg neg camber on the rear and 1/8 toe in.
My front is similar but i maxed the caster, the car is rock solid on the highway and has good self centering.
Stock konis and torsion bars
