Old 07-21-2013, 09:47 PM
FWB's Avatar
FWB FWB is offline
here's the link..
Ford 427 Cobra Kit Car - Kelowna Collector Cars For Sale - Kijiji Kelowna Canada.
looks nice ....only things i see that stand out is, all the screws around the cockpit trim is weird.
he mounted the exterior door handles on the interior for some reason.
the engine still has the factory iron heads on it and the external voltage regulator charging system.
advise is to verify the cooling system is adequate by letting it idle a while in the heat and see if the temp soars. may need a fan shroud most don't come with one.
need to drive it....make sure the trans downshifts when you romp on it.
not any room for the factory kickdown rod.....you have to retro fit a lokar cable for that
Fred B
