Old 07-21-2013, 11:30 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Originally Posted by kdavies3 View Post
Thanks Stefan,
I had to junk the pads that were the Wilwoods I got from you.
They were just too hard without a servo.
I've gone with EBC greenstuff pads now which is better but still not as good as I'd like the front brakes to be.
I may try an even softer pad or fit a remote servo in the longer term.
I had to fit a pressure restrictor in the rear brake line to stop the rear end locking up first.
I'm going to replace the restrictor with an adjustable valve so i can optimize things.
I am running Polymatrix E type compound pads , and braking is vigorous without any power assistance.
For the rear i have a Wilwood proportioning valve to limit the pressure to the rear brakes. Takes some brake testing to find the good adjustment. Once set you can leave it like that.
Nothing sounds better than a Cobra in a Tunnel !
