Old 07-21-2013, 11:07 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
it is also very important that you plug ALL the holes in the firewall and make them airtight. I had heat coming into the foot well until I discovered that the hole through which the gas pedal linkage went up into the engine bay was letting lots of hot air in. Finally installed a small rubber bellow over the shaft and problem solved.
Nothing sounds better than a Cobra in a Tunnel !
