  #156 (permalink)
Old 07-22-2013, 12:03 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
A bit of a shed update. I started building a heavy duty steel fabrication table a while back. With all the distractions I seem to fall victim to it's been sitting gathering dust. I got stuck into it over the last week and it's getting close to finished.
It measures 8'x4' and will have a 10mm steel top on it eventually. I've set it up so it's got sockets at various points around the table so you can plug tools and fixtures in rather than having them permanently fixed in place. Things like the vice or a tube notching tool can be plugged in and used and then put away when not in use. This should give a lot of flexability for doing different jobs.
I've got all the cross members welded in now and the sockets done at one end of the table. Just got to finish off the sockets at the other end of the table and weld the top on.
Mike Murphy
Melbourne Australia
