Old 07-22-2013, 08:11 AM
BAsque1's Avatar
BAsque1 BAsque1 is offline
Originally Posted by FWB View Post
here's the link..
Ford 427 Cobra Kit Car - Kelowna Collector Cars For Sale - Kijiji Kelowna Canada.
looks nice ....only things i see that stand out is, all the screws around the cockpit trim is weird.
he mounted the exterior door handles on the interior for some reason.
the engine still has the factory iron heads on it and the external voltage regulator charging system.
advise is to verify the cooling system is adequate by letting it idle a while in the heat and see if the temp soars. may need a fan shroud most don't come with one.
need to drive it....make sure the trans downshifts when you romp on it.
not any room for the factory kickdown rod.....you have to retro fit a lokar cable for that
I agree wholeheartedly with FWB by the way good eye for the voltage regulator. The 429 CJ engines had about 370 HP with the big 700 cfm carb. I am a believer of the cast iron vs aluminum engines and heads so that does not bother me much that it still has them. The question is how old is the engine and what was done to it prior to putting this car together. That said, I don't anticipate that this car was assembled by Vern, he likes the 460's .
The cooling system is very important, particularly in these cars if you go over 180 degrees in idle you will feel it in your legs very quickly.
Lou
Basque1
