Thread: Bolt on Hubs
Old 07-23-2013, 08:49 AM
ERA2076 ERA2076 is offline
Cobra Make, Engine: ERA - B2Motorsports Dart 331
Bob - thanks for talking with me. I am trying to fit the widest rear wheel recommended by Roger Kraus Racing for the Avon CR6ZZ 295.50.15.
Using the Jag five lug hubs the rear wheels push outboard .375.
Mounting a 10.5 Tye R wheel and increasing backspace to 4.5", the rear wheels should push outboard an additional .025.
Most of it goes to the inside and as you said there is lots of room in there (although Chas has some concern). Will have to look at that when I get home for function and aesthetics, but it seems promising.
I am thinking of purchasing and drilling a proper sized Rock Crawler steel rim for the 6 pin, mounting the tire on it, spacing it 3/8", and cycling it.
I Plan to start with Wilwood for the front hubs. Are the bolt on front hubs you use off the shelf?
I look forward to seeing the info you sent.
x-cliff
