Old 07-24-2013, 05:00 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
i wouldn't use the cork. you can use a paper gasket or not, but get some of 'the right stuff' gasket maker and smear a thin coat on the tank, both sides of the gasket if you use one, but it should be thin. put some on the bolts to hold them in and put it all together with about 12-15# tq. let sit overnight. also make sure surfaces are clean and flat. also make sure your bolts are not bottoming out but give you the longest reach you can use, might have to stack washers if the bolts are too long.
