Old 07-28-2013, 07:19 AM
ERA Chas ERA Chas is offline
Originally Posted by lippy View Post
It mounts on a pedestal directly behind the passenger side wheel. You remove the panel behind the wheel for access. I have the optional heat vent and heat shields, and I am going to add either heat shlelding on the bottom of the pedestal, an insulated battery cover Thermo-Tec : Battery Wrap Acid Absorbing Heat Barrier, or both.
Think.
You're making a maintenance nightmare for yourself. The valve cover will have to come off for batt changing or service / testing. Trickle charging with a Battery Tender also not easy. With the shields and the other crap, access is very problematic. Header gaskets and pipe fits are harder to access. And a 36 pound Optima installed over the fender top and bending inward gets old fast. A battery cover makes it 10 x's worse.
I'm not just talking through my ass; in the 90's, when I rebuilt the car for the second time, I had all that crap.
Heat shields, batt on footbox. In six moths, I tore it all out; batt in trunk, kill switch on bulkhead, no heat shielding. Improved weight bias, EASY battery and header maintenance, longer batt life.
As I said another time, you're over-worrying this. Trying to make a C6 out of a Cobra. You wanted Brent's big power but you're weighing the car down with junk and a radio.
Cobras are elemental, they produce heat and noise. If it's the right car for you, none of those elements will deter you.
Chas.
