Old 07-30-2013, 02:52 PM
SPF1061's Avatar
SPF1061 SPF1061 is offline
Cobra Make, Engine: Superformance Mk III / Windsor platform
Default electrical system dead
Turn key - absolutely nothing happens. Won't crank, no lights, no horn, no fans, no nothing. Behaves as if the battery is not connected. I have charged the battery and it is good. I have checked the battery ground to the frame just below the battery box and it is good. Ground connection from the starter to the frame is good. Any suggestions on what/where to check next. Is there any sort of major relay or main fuse that could cause this? Ignition switch bad?
Thanks for any help.
