Old 07-30-2013, 06:42 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
We are looking into this issue offline. Since he has no headlights or brake lights, the problem is the main power feed from the battery. He had already replaced the battery, and verified the main chassis ground at the battery. So we are now checking for power track, first at the firewall mounted solenoid, then for power at the main fuse, then thru the fuse. Next will be the feed to the AMP meter, and thru the meter.
On a SPF you always have brake lights and headlights and fans when the car is not running. (With a few exceptions on selected chassis #'s on the brake lights - but that is another story) We'll follow the current path and find the fault. He will post his findings....
SPFWiringDiagrams@Comcast.net
