Old 07-30-2013, 11:51 PM
Jethrow's Avatar
Jethrow Jethrow is offline
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Originally Posted by muzzza View Post
Tim, Have a couple of pics of my header tank set-up in my gallery. .........works really well. Moroso header tank feeds into thermostat / heater housing, with another Moroso tank purely as an overflow. I run coolant about 40mm down from top of tank and it has never expelled coolant into the overflow tank. I also run the 63 deg thermostat. Murray
Thanks Murray. Looking at your photos, your install looks really neat. I also like how you added a temp probe in the other heater outlet point. I put mine on the other side of the water pump where there is a blanking plug.
On a different subject how easy is it to fit those valve covers? I have considered getting a set but am unsure on how they fit, especially with what to do with the coil packs. Ideally they will stay in the same point they are now, but I am not sure if those covers fit over the top or not.
Thx
Tim
FFR Mk4 Roadster
HSV Clubsport R8
