Old 07-31-2013, 05:18 AM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Hi Scoob, I have had my Round Tube CR on the road for about 4 years now and covered about 12,000Ks.
The front suspension mods the guys spoke about I have made too.
After 7000Ks my upper rod-end was worn and I had excessive play that you only noticed when the suspension ws loaded (i.e. not on jacks etc).
I also had a bit of nervous twitching a little while back and found I had my passenger side shocker set to "hard" and the driver side to "Soft". I have them both set to soft and it is much better. I only set them to hard on the track.
Regarding bump steer, I would have thought that bump steer would be evident when you slam on the brake as well? Is this the case for you?
Also, I have finally sort my brakes out so give me a yell if you need some tips on that.
All in all it handles quite well on the road. have had it on Winton (3 times) and Wakefield(once) and it handles quite well.
Hope this helps.
cheers
Gregg
