Thread: 463 IR Windsor
Old 08-05-2013, 09:56 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by meanone View Post
The Dart sportsman blocks are not cross drilled in the front like there iron eagle blocks. we at Kuntz and Co. have found it advantageous to oil the front pair of lifters at the same time as the back pair. Pushrod and rocker life is much better oiling from each end. This is handled in a different way on Iron eagle blocks. This actually helps the hydraulic lifters even more as they have to have a lot of oil supply and pressure to stay pumped up. As we all know with conventional oiling 1 and 5 cylinder pushrods are always the first to fail.
That is really interesting, and I have never heard of this before. I am using a Dart sportsman block.
I have not had any problems with the lifters. But, I have had the the #1 rocker arm nut come loose more than once - despite a lot of torque and lock tite red. Next time I overhaul the engine (every other year at least) I will be doing this oiling mod.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
