Old 08-06-2013, 08:34 PM
lippy lippy is offline
In the past I've always used the two person method. It's a bit of a pain but how often do you bleed your brakes? I don't like tha vacuum devices because they tend to pull air around the screw threads. Pressure bleeders look like a good alternative. I spoke with Bob at ERA and he mentioned they usually use the gravity method. I've read this too can be a pain, but if it works it works well.
