Old 08-07-2013, 09:35 PM
Tom Howland Tom Howland is offline
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
I've had that same problem. You need the proper plug for the threads in the head and the proper heat range for the combustion ratio. I now use MSD spark wires with straight boots that can be bent at an angle away from the header tubes. They have helped but #7 is still a little crispy.
Tom
