Old 08-08-2013, 09:06 AM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by Jerry Clayton View Post
Arthur----
The flow out of those cylinders are away from the spark plug a little bit and a pretty good sized dimple in the header tube wont hurt your performance( it might even increase the flow numbers!) Take a medium sized ball peen hammer and set it on the header tube where you need the clearance and tap it with another larger hammer to indent the tube for a bit more clearance----work it patiently (whats a 1/2 hour added to 10 years?)
Good to hear that you are driving it this summer-----
Hello Jerry, Yes I'm going to do some dimpling on the headers when I remove them from the car. There is insufficient room to be able to make even the slightest hammer tap.
I'm still going to pursue finding a shortie spark plug for a better fit. A 5/8" hex size spark plug would be necessary too. I'm hoping I can use tapered seat plugs too, but I'm still trying to determine what the engineering/design criteria needs to be at the spark plug hole in the head to accept the taper seat plug.
BTY, I believe that running my new engine on the Dyno may not have beeen the best idea. Not sure what could have gone wrong but, I'm blowing a ton of oil out of the PCV 1 1/2 quart in 200 miles. You may recall that I built the engine back in 1987, perhaps parts/rings from that era may not react too well to the high reving stress. I think perhaps I should have followed the traditional break in procedure by driving some 500 to a 1,000 miles before a dyno run.
Hope al is going well with you,
Arthur
