Old 08-08-2013, 07:36 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Gathering parts
I have begun a project to put Webers on my build and am gathering the parts for the project.
Research shows that most guys are running spacers, but few posted how thick they were.
I currently have 3x2's installed on the FE motor and heat is a little bit of an issue when the motor/ambient temp is high - vapor lock. A friend has weber's on his 289 and they would drip if the heat was high. All reasons to reduce the bowl temp as much as possible.
I will be ordering the phenolic and didn't know what thickness worked the best.
Paul
www.65shlb.com
www.prdcrrct.com
