Old 08-09-2013, 05:15 AM
Chilibit Chilibit is offline
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
Originally Posted by Varmit View Post
The Smith's speedo has a problem with the little reset dial for the trip odo. When I try to reset the trip odo to zero it just spins, so I am assuming the plastic gears are either worn or stripped. I see there is a small retaining nut on the bottom of the dash with the adjustment knob. Can this mechanism come our and be replaced without pulling the entire speedo? And can this be replaced without a new speedo?
In my own case I know that if the cable used to do the reset is disconnected from the dash and allowed to have less severe bends that it works. Secured to the dash it does not. So I just let is lay up out of sight. You might try that first.
