Old 08-09-2013, 06:20 AM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
I use the tube in a jar method but I have a one way valve in the tube. Also I pump 3 times, then open the nipple. If I'm flushing, you just keep pumping. You just have to make sure you let the pedal come right up, or else you block the bypass hole in the MC. I'm still wondering the best way to bleed the master from new without making a mess once it's already installed?
I have the twin master setup, Is the balance bar supposed to flop around, It looks ungainly not pushing central like a single setup? I've never had anything to do with this type.
JD
