Old 08-09-2013, 12:15 PM
joyridin''s Avatar
joyridin' joyridin' is offline
I do not have Wilwood calipers, but I have converted my early Jag to vented 11.375" x .944" vented rotors. Not an easy task, but doable. Chas sent me pics and I copied.
What you probably want to do it work with Mickmate and put Wilwood vented rotors on the car with Wilwood calipers. It is very doable. You need a rotor adapter he can easily make and the Wilwood bracket he probably already makes. The catch is the e-brake. You will have none so you might have to put a line lock of some sort. You can put 11" disks without any problem. Bigger than about 11.5" diameter and you might have a few minor problems.
