Old 08-10-2013, 06:28 AM
750hp's Avatar
750hp 750hp is offline
Thanks Rick. I wish I liked the look of the dual carb cross ram manifolds because they're much easier to find! I wonder if the only option might be Hogan's or Marcella for a sheet metal intake?
Originally Posted by RICK LAKE View Post
couple of guys have used the crossram manifold with out the distributor extension housing and gone to FI. Everything is under the top and uses to throttlebodies. the injector are mounted into the runners. This is not a bad manifold but needs some work for flow. Good luck Rick L.
Craig
