Thread: Best EFI System
Old 08-10-2013, 11:21 AM
Luce Luce is offline
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
Another question you may ask yourself is how much of it are YOU willing to learn and do yourself.
There are off the shelf "self learning" units that have been set up to work OK with as many engine size and behaviors as possible to recoup as much R&D as possible, then there are the real systems where you pick the hardware and configure an ECU to work it.
Two questions you must balance. How much extra hair do you have that you are willing to pull out and how deep are your pockets.
I did a megasquirt 2 running a Victor intake with bungs and a 4 barrel looking throttle body. The only thing I would consider doing different (If I had it to do over) would be 8 stack.
