Old 08-11-2013, 03:58 PM
BAsque1's Avatar
BAsque1 BAsque1 is offline
Originally Posted by steve1h View Post
This only happens once in a while.
The motor turns over hard and the car will barely start after a run to full temp. This will happen sometimes, even if the car has sat for a couple of hours or 10 minutes.
351 approx. 400hp. The cars always runs great, no other problems. Thanks for any ideas. This never happens after the car has sat overnight.
Steve:
I had the same problem and it was a multiple solution type problem, so far what they have said about insulating the starter it is true, however, you might need a high torque starter.
I changed mine and in addition it is well insulated, check your gas lines and their proximity to the engine you might want to insulate them as well.
I installed a 1/2 " phenolic spacer for the carb, I changed the gas filter and ensured that my air filter was the appropriate one as well.
How is the engine temp, optimum temp is bout 180-190* if it is over than that you might want to check your coolant, I use Prestone less than 50:50 ratio plus water wetter. Open road I am doing 180-185* short and stop 200* that's when my fans kick on. This is just to start with. I hope that this gives you some ideas .
Sincerely
Lou
PS
Make sure that you are not over boiling the gas and emptying the carb bowls when the car is turned off.
here is a link to the responses I got
Hot engine hard to re-start Vapor Lock???
Basque1
