Old 08-12-2013, 05:57 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Pedal mods for Coyote
Looks like I forgot something. After slicing up the $250 pedal assembly as you can see in the pics I took a piece of 1" box tubing by 4" long and cut out one one of the sides (effectively making it a U Channel) and then slid it over the remaining nub of a pedal. With the U channel positioned over the nub I Cross drilled a 1/4" hole to hold the U channel to the nub. I then too a 1/8" X 2" wide X 5" long piece of flat stock with a 1/2" piece of box tubing welded to the the back of the flat stock as a riser and welded that to the u-channel. Bolted the modified pedal to the assembly and attached it to the pre made bracket under the dash. All in all it took me a couple of hours.
"Let's roll"
"Be part of Something Good
