Thread: Lifter adjust
Old 08-14-2013, 08:05 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
What's the point of spending ..thousands... on the engine components and then not getting the valve lash right..........every thou...of gap at the valve stem reduces valve lift..........also Patrick ...that big bar onvthe crank nose is not going to be such a good idea when that center bolt strips the threads in the crank nose..............its happened to me..........if youre going to do it that way ..take the plugs out firsts so the motor turns easy......
