Old 08-18-2013, 03:53 PM
DanEC's Avatar
DanEC DanEC is offline
Patrick - if you don't mind, what is the distance from the clutch pedal face to the seat cushion (nearest point) on your car? And the face of the clutch pedal to the footbox?
ERA 778 - mine sounds like your setup except I have a toploader - Quicktime, McLeod diaphragm clutch, spacer. Thanks for the cmts on the 1 inch Triton
Bob - it's a 3/4 Titon. I looked at it while under there. I think this one might be toast anyway with some leakage and the scored shaft?? I wouldn't call the pressure light but it's not bad. Does a 1 inch one sound right? By area increase that should shorten the pedal stroke about 40%.
