Old 08-25-2013, 04:57 AM
BAsque1's Avatar
BAsque1 BAsque1 is offline
Originally Posted by Ron61 View Post
I am guessing that your tach is electronic. Since you removed the Alternator, I would check all grounds to be sure that one of them isn't loose or dirty. Also even though you had the Alternator checked out, it could still have a bad diode in it that would cause problems once you put any load on it. I have had a loose belt before on some cars and normally the screeching doesn't go away after a minute or so but will happen every time you get on it. How easy does the Alternator turn when it is cold and you turn the pulley with your hand?
I agree with Ron, last year my alternator literally died in the middle of a nice run in Lake George. The tach was the 1st give away for it went ballistic on me. After I purchased a new alt the tach had apparently damaged and I ended up buying a new one. These electronic gauges are extremely sensitive to power surges and are easily damaged.
The other check up points are very valid and must be verified especially ground wires.
Good luck
Lou
Basque1
