  #21 (permalink)
Old 08-29-2013, 11:26 AM
lippy lippy is offline
Originally Posted by Paul F View Post
I have a teflon line for my clutch slave cylinder. I had an electrical issue which made pinholes in the line. I replaced it once without understanding what happened and it did it again.
Having teflon line buried in the frame may cause the same problem. I'd rather have the line under the body so any leaks will fall to the ground, not collect in the frame.
Granted, my condition is peculiar, but it happened.
What exactly was the cause of your issue? My fuel line is mostly under the body, attached to the frame with rubber-padded clamps. It only passes through the frame for about 2" above the rear suspension.
Separately, this hose is rated for use in -100 degree F to + 450 degree F conditions. That should be adequate, but I may still insulate it where it passes relatively close to the headers (but not too close). Thoughts?
