Thread: Demon carbs
Old 08-30-2013, 08:25 PM
DAVID GAGNARD's Avatar
Have had a Demon on my race car (331 stroker) since day 1 (2005) and have only one complaint...the base plate is CNC'd out of soft aluminum and where the 2 throttle shafts go thru the baseplate there is no metal bushing like in a Holley and after time,in my case 2.5 years, the metal throttle shafts eat out the soft aluminum and you get a major vacuum leak.......had to replace the baseplate........
Other than that,I like Demon carbs, all other workmanship was first class and everything from a Holley will pretty much interchange on a Demon....easy to tune and once tuned properly I didn't touch the carb except for the baseplate replacement.......
David
DAVID GAGNARD
