Old 08-31-2013, 06:45 AM
*13*'s Avatar
*13* *13* is offline
600 is not too small, if you don't plan spinning higher RPMs. In fact, a 600 cfm carb will have a snappier response.
RPM range is really the key. If you are trying to pull large amounts of air through the carb(higher rpm) you will need larger cfm. If you have a larger cfm, lower volumes of air have a more difficult time pulling fuel out of the Venturis(poor response).
So, the carburetor needs to be selected for its use, not max RPM
ERA FIA 2088
