Old 08-31-2013, 12:26 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by PaulProe View Post
I would like to run a bypass style system with my new Weber setup. I've had some heat issues in the past so letting the fuel return to the tank sounds like a good idea. But I can't find a regulator that will bypass and also go low enough to make the Weber's happy.
Is anyone else running a bypass system or does everyone just deadhead to the Holley Low Pressure regulator?
Paul
you could run the regulator you use now and add this, (see link) and adjust to blow pressure at the level you need.
Adjustable Pressure Relief Valve for Belt Drive Fuel Pump - Speedway Motors, America's Oldest Speed Shop
Fred B
