Old 09-01-2013, 05:03 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Paul,
Not running Webers but using a Holley on this car. Had quite a few heat issues with the carb: First Coast Cobra Club • View topic - Zephyr update June 2011
Pretty sure the reg is an Aeromotive 13204 (been more than two weeks since I put it on). Any reputable return-style reg should work fine.
Then I found that some of the problem, maybe almost all, was the fuel pressure gauge: First Coast Cobra Club • View topic - Liquid filled gauges - lesson learned!
Any more problems and I put EFI on the dang thing...
Hope this helps,
Tom
Originally Posted by PaulProe View Post
I would like to run a bypass style system with my new Weber setup. I've had some heat issues in the past so letting the fuel return to the tank sounds like a good idea. But I can't find a regulator that will bypass and also go low enough to make the Weber's happy.
Is anyone else running a bypass system or does everyone just deadhead to the Holley Low Pressure regulator?
Paul
