Old 09-02-2013, 07:50 AM
AL427SBF AL427SBF is offline
Originally Posted by *13* View Post
600 is not too small, if you don't plan spinning higher RPMs. In fact, a 600 cfm carb will have a snappier response.
RPM range is really the key. If you are trying to pull large amounts of air through the carb(higher rpm) you will need larger cfm. If you have a larger cfm, lower volumes of air have a more difficult time pulling fuel out of the Venturis(poor response).
So, the carburetor needs to be selected for its use, not max RPM
Good advice, it's the throttle response vs. peak HP trade and what RPM band you will do most of your driving. Seems the cam also plays a role, I know my builder got with comp cams to discuss and agreed that a 650 willy's was the ticket for my 427w.
