Thread: Clutch problem
Old 09-02-2013, 04:14 PM
Danr55's Avatar
Danr55 Danr55 is offline
I would look first at the clutch cylinder. Sounds like it has worn a soft spot in the middle and needs to be replaced. THat would be doubly true if it happens when you sit for a minute holding the clutch down. The fluid leaks around the piston.
Dan in Arizona
CCX3209
