Old 09-02-2013, 06:50 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Source
Originally Posted by Gaz64 View Post
I ran a Mallory 4309, quite easy to run a softer spring and get 1-6 psi instead of 3-12 psi.
Gaz64
Is the lighter spring easy to find or did you just luck onto one?
I'm also curious about your comment to modify the Holley regulator turning it into a bypass type
Paul
www.65shlb.com
www.prdcrrct.com
