Old 03-21-2002, 08:41 PM
mustangarino mustangarino is offline
My first post....Denny, if you do pull the tranny to inspect the bearing, remove the banjo fittings,and install 90 degree elbows to the bearing, then put a standard female fitting on the hose and connect it to the bearing. I "had"one on my toploader and the banjos were a nightmare. As far as pedal travel goes,your is that long probably because of a problem with your bearing, or you have air hiding in your system.
