Old 09-04-2013, 09:36 AM
DanEC's Avatar
DanEC DanEC is offline
If running PVC then you need one passive breather somewhere - manifold, oil filler tube or valve cover breather. If not running PVC then current wisdom appears to be to run two breathers. On the FE, with some intakes you can do that at the manifold (oil filler tube and rear breather mount). Or a breather on each valve cover. Or a combination of the two.
