Thread: Demon carbs
Old 09-04-2013, 08:53 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Originally Posted by OldFoggey View Post
I just ordered the all black Holley 4150 (part number 0-76750hb) double pumper from SummitRacing since it does have an electric choke, mechanical secondaries plus 4 vacuum ports so I can eliminate the spacer I'm using to get the second port. I've read several reviews and it seems to be pretty much an out of the box bolt on accessory.Hopefully this will end the idle quirkiness I've had since purchasing the car last July.
Don
Don't be fooled with Holley's "Out of the box and go" rhetoric. Especially if you purchase from someone other than Holley directly. I have heard many horror stories of carbs that didn't work. Like mine. I suspect that someone else bought this carb, messed with the settings, and sent it back. The store just re-boxed it and sold it to me.
I bought a Street Avenger (non-ultra) 670 with vacuum secondaries. Put it on expecting it to run perfectly. It was anything but perfect. Idled at 2000. No adjustment on the idle (hot or cold idle). Eventually figured out how to get it tuned right.
My suggestion is to get a book and learn how to tune the Holley. Another option is to search Youtube or purchase the Holley DVD from Boxwrench (highly recommended for a Holley learner).
Here is my $0.02 on setting up a Holley carb. Not sure it if works with any other brand, but will likely work on carbs based on the Holley design. I fiddled with this carb until I finally did it this way. Not sure where I got the final piece of the puzzle from, but it worked.
Originally Posted by Texasdoc;
1. Make sure there are no air leaks.
2. Warm up the car.
3. Set the float levels per Holley's instructions.
4. Set the idle mixture screws per Holley's instructions to best vacuum.
5. For those with vacuum secondaries, remove the line that runs to the distributor and cap the hole on the carb to prevent vacuum leak.
6. Make sure the choke is off - for manual, just use the lever. For electric, push the choke (fast idle) cam down.
7. With the carb off the car, set the PRIMARY blades by using the curb idle screw so the idle transfer slots as viewed from the bottom of the throttle blades are square (really just a dot). Again, make sure the choke is off!
8. Now put the carb back on the car and adjust the idle by turning the SECONDARY throttle blades adjusting screw. This is hard because Holley puts this screw underneath the throttle plate. I have an airgap intake, so I found a small screwdriver that fit and I didn't have to take the carb off repeatedly to make this adjustment.
9. Go back and attach the vacuum line to the distributor (if applicable), recheck your timing, and adjust your electric choke (if needed).
The biggest problem I had was that my Secondary blades were open way too far when I got it new. I had the curb idle screw all the way out, and it was still idling way too fast since the secondaries were so far open. Setting the PRIMARIES with the transfer slot just visible, then adjusting the IDLE by adjusting the SECONDARIES sets them both where you want them to be. Now, if you need to adjust the idle, you can use the curb idle screw for small changes.
Also, attaching the vacuum advance distributor to a manifold vacuum, not a ported vacuum really helped smooth out my idle. There is alot of debate on this subject - too long and off-topic for this post.
Good luck with the new Holley! I've thought about switching to a mechanical secondary 750, but I'm running so well with the vacuum 670, I don't want to mess it up.
