Thread: Demon carbs
Old 09-05-2013, 09:47 AM
DAVID GAGNARD's Avatar
Don't be fooled with Holley's "Out of the box and go" rhetoric.
X 1000.......
There IS virtually NOTHING you can buy and bolt on "out of the box and go"...everything especially carbs will need some adjustment....the Holley carbs are jetted slightly rich form the factory as they have no idea if they are going on a basically stock engine or highly modified engine,the carb will have to be tuned to each individual engine for the best performance.....
Although the Holley should be close,I doubt if will be perfect out of the box....as Texasdoc said,it's not hard to tune a Holley and if you follow his instructions you should be fine.......
David
DAVID GAGNARD
