Old 09-09-2013, 04:10 AM
mdross1's Avatar
mdross1 mdross1 is offline
Wilwood will take care of your problem.If the pad compound is correct it could be the masters need to be a little smaller.We picked up a pressure gauge to check line pressure.
Our problem was the rods that operate the masters had to be moved closer to the brake lever pivot to get the required line pressure.Good Luck
