Old 09-12-2013, 07:13 AM
jualwatt's Avatar
jualwatt jualwatt is offline
Cobra Make, Engine: Backdraft 1134, Roushcharged Coyote Aluminator NA
Originally Posted by twobjshelbys View Post
Re: LEDs. The problem with the LEDs is generally they point one direction whereas the bulb is 360*. The tail lights depended on the filaments and bulb being "exposed" since the bulbs are upright instead of straight out the back. There are some LED replacement bulbs of that type that have side LEDs that do project that direction. Be sure you see a picture before ordering.
Front facing LEDs are much brighter. Like I said, tail lights are "dim".
In the first link I showed above, the viewing angle is 320 degrees due to the built in reflector lens even though it is a single hight intensity LED. I am going to give it a try and see how it works.
Julian
