Old 09-12-2013, 01:55 PM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by Bdsiny View Post
I have a csx 4000 series 427 s/c cobra. The car overheats regularly. I have put in water wetter as well as water constantly cause it pisses out after too hot. The front two propeller fans are not working (previous owner said he disabled it) not sure how to get them going again. Fuses? Also , brake lights don't work. And just recently, the fuel pump switch stopped working?? Any help ideas would be greatly appreciated Thanks
. As far as overheating, are you using a combination of anti-freeze and water, or just water in your radiator? Also, when the motor is running and warmed up, is the electric fan located on the back side of the radiator kicking in? If not, then either the fuse is blown, or the inline thermostatic switch is faulty and needs to be replaced. Since the fuel pump, brake, lights, and cooling fan are on separate fuses, I suspect a short somewhere in your main wiring harness.
Where are you located, as there may be a few "cobra friendly" shops we can point you towards.
Bill S.
