Old 09-12-2013, 05:39 PM
Dimis's Avatar
Dimis Dimis is offline
Originally Posted by Bdsiny View Post
I have a csx 4000 series 427 s/c cobra. The car overheats regularly. I have put in water wetter as well as water constantly cause it pisses out after too hot. The front two propeller fans are not working (previous owner said he disabled it) not sure how to get them going again. Fuses? Also , brake lights don't work. And just recently, the fuel pump switch stopped working?? Any help ideas would be greatly appreciated Thanks
Sounds like a nice car, bar the wiring...
The other electric fans are working. With the switch or on its own while hot which is good. I believe it's just water and water wetter fluid I'm in Staten Island New York Also need carb work. Backfiring etc. any help would be great.
So with that, I've got a stupid suggestion:
Any chance the wires to the fan (not the pusher fans out front, but the puller fan between the radiator and your pulley system) are on the wrong way, causing the fan to spin in the wrong direction?
