Old 09-13-2013, 07:27 AM
cobra 53's Avatar
cobra 53 cobra 53 is offline
Cobra Make, Engine: NAF 289 Blue/White strips
Default Valve Lash Setting
As I could learn from several information concerning the procedure to set the valve lash, it always starts with:
"when the EXH valve starts moving, then adjust the INT valve on this cylinder".
Is it possible to set the valve lash when the pistons on the SAME cylinder are on the TDC and FIRING position?,
If this is the POINT where both lifters are off of the LOBE, are there any inconveniences to work with?
Rico
Rico, NAF 289
