Old 09-13-2013, 07:32 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by cobra 53 View Post
As I could learn from several information concerning the procedure to set the valve lash, it always starts with:
"when the EXH valve starts moving, then adjust the INT valve on this cylinder".
Is it possible to set the valve lash when the pistons on the SAME cylinder are on the TDC and FIRING position?,
If this is the POINT where both lifters are off of the LOBE, are there any inconveniences to work with?
Rico
here's a chart i found that may make it clear
Fred B
